Case grommet holes ARGHHH...
paulstung
I need a rant, why oh why have I never had a case were the 24 pin grommet is in the right place for a 24 pin cable to go through, it is either too high or to low ? I understand that every motherboard has a different 24 pin location, but I've had different motherboards, and every time it is the same, the 24 pin cable either has to go up or go down.
I've noticed that most cases have 2 or 3 grommets, the one's with 3, why is there one so high up, above the 24 pin ? why not get rid of that and then just have 2, then the top one can be a little higher, allowing the 24 pin to be straight ? Then the ones with 2 do the same thing just make it slightly higher.
I've had the same problem with every full size, or mid tower case, and motherboard I have ever owned it is a pain in the back side, all I want is a nice and straight 24 pin cable it's not a lot to ask for is it ? GIVE ME BETTER GROMMET LOCATIONS PLEASE
Dremel is your friend :D
Corsair certainly won't listen, MANZ JUST WANT MOAR FEATUREZ!!!!!!! Features and features and features sell bare cases for days.
JR
My Z77 MPower with Switch 810 are fine nice and straight
I had the Z77 MPower, in a Phantom 630, and they were close, about the best I've had anyway.
I'm debating on weather or not to stealth the motherboard tray, with the rear of the cable tie down points and grommets on my Enthoo Luxe, it all looks too busy, compared to the rest of the build, so A Dremel it will have to be.
