I'm about to buy a new car, probably the Honda Jazz. I looked up online and I couldn't find what speakers size it has places for. (I'm a noobie when it's about cars) and I was hoping to find some good recommendations for receivers and speakers (again, I couldn't find the sizes) I just know it has place for 4 speakers + two tweeters (not sure if I should occupy them)
What I look for in the receiver:
Flac support, Bluetooth, no touchscreen, High quality sound, reasonable + EQ, not needing a separate amp (probably not going to be a concern, because I'm not getting a subwofer)
What I look for in speakers:
Clear and detailed sound, not bass heavy, not very loud, close to flat so I could tweak the EQ as I see fit (I usually lower the highs a bit and keep the rest almost flat, but I like to play around with it)
I listen to a lot of genres mostly jazz and rock, but I also listen to other types of music like 8-bit, blues, classic rock, sometimes metal, sometimes classical music..
Budget for the audio system (without tax, shipping or installation) is up to $1000 max, preferably less though.
