name='cheap' said:usb is enabled in bios!
name='Animal' said:Have you enabled it in bios..?
stocky said:You got all the wires in the right places; on the mobo and control board?
I had an issue with having to re-wire a USB cable to suit...
stocky said:On control board the USB cable should be aligned like:
From main ribbon connection: RED > WHITE > GREEN > BLACK > Spare Pin.
And then what ever you mobo has.
stocky said:Sounds like you may have found your problem...
But sometimes the mobo is different, as long as they match up on the mobo correctly it'd be okay.
The colours I have shown (in above posts) identify what the pins are in their position on the control board:
RED = Power
WHITE = Data+
GREEN = Data-
BLACK = Ground
name='stocky' said:That's right, just edited my post (must have had a spasm when I was typing) Just make sure the correct pins match between the mobo and control board.The photo doesn't lie! Good luck, and let us know if you get it going!![]()
stocky said:No probs
Report back and let us know how you get along!
