Can't Get Rid Of GPU Temps/CPU Temps In Game
SpencerUk
In this game and Tomb Raider I appear to get this GPU overlay..How do I get rid of it?
I don't have anything like RivaTuner, Afterburner installed.Just have the AMD Radeon software thing and there's no option in to remove it...Also there's no option in steam..Any ideas folks?
I've been using CAM and it's not bad. Coming from Afterburner the only thing I didn't like about Asus GPU Tweak II is that there is no on screen (in game) display.
Something that would be good would be an offset for the OSD. The positioning options are okay but generally there are things in those corners already when you're in the menus etc
An offset Up/Down/Left/Right whatever by x amount of pixels would be perfect.
That is a great idea! Email the developers as it should be quite easy to implement.
