Hi guys.
I am new in OC3D! Here my greeting (http://forum.overclock3d.net/showthread.php?t=72956) I have to admit I am a total noob. So, excuse me if I may ask silly questions.
I come from the Mac world, and I am used to have everything up and running just out of the box. Now I decided to change back to the PC world, with this config:
I am absolutely unable to set the XMP Profile and get my Kingston HyperX to run at 3.000MHz. I can only get my system to boot in "auto" which sets the DDR4 modules to run at 2.166MHz.
I've read in the ROG forums that I have to set the XMP profile and try to move the System Agent Voltate in 0.01v by 0.01 to find the stable spot.
I did that, but never got my system to boot, and when it does, it goes straight to a windows blue screen of death.
So, after all this pain I am seriously considering to return everything to Amazon and by a new Mac, unless I can get it to work stable at 3.000Mhz.
I would like to ask some questions if I may:
1) When I set the XMP profile it automatically changes the BCLK to 125. Do I really have to OC my CPU in order to use my DDR4 at 3.000MHz? Can I keep my CPU running on "normal" speed BUS and multiplier, and have the RAM going at the (certified speed?) Or is mandatory to increase the BCLCK to 125Mhz?
2) Is there any set of DDR4 modules 3.000Mhz that work "out of the box" using XMP in the Asus Rampage V Extreme?
3) Am I missing something? Is maybe my motherboard, or chip or RAM broken? Or is me, that I just don't know how to set up my BIOS to the correct settings?
If somebody can give me a hand I would really appreciate it.
Thank you in advance!
- Processor: Intel 5930k 3.5GHz 15MB 40 Lanes
- Motherboard: Asus Rampage V Extreme 3.1 X99
- Cooling: Corsair H100i GTX Hydro
- RAM: Kingston HyperX Predator DDR4 3.000MHz 32GB (4x8G ) HX430C15PBK4/32
- SSD: Samsung SM951 NVME 512GB 2.200MB/s
- Graphics Card: Asus Strix GTX 980 Ti 6GB
- PSU: Corsair AX1500i
- Cabling: Corsair Individually.S Red Cables
- Case: Corsair 780T
- Monitor: Asus PG278Q 144Hz G-Sync TN
- Keyboard: Corsair K95
- HDD: WD 3TB Red SATA
