Can I use two BT routers together?
lf751
I got a new BT router in the post and I want to use my old one for the PC upstairs, problem is that the both wont work together, how do I fix this? :sleep:
If you are connecting each seperately to its own phone point, you can only have 1 of them synched at the same time. If you are routing from one to the other then I'm not sure how to do that :S
are you using one as a adsl router and one as a wireless repeater? or am I missing something :confused:
2 routers sync'd on one line?! :eek:
you cannot use two adsl routers on the same line.
you are going to have to connect the two routers via an Ethernet cable if you want some ports upstairs and downstairs.
2 adsl routers on the same line = 24 hour shut down of you connection
(well it used to be, not sure now).
