Call of Duty: Advanced Warfare Console Resolutions announced
I kinda like the movement in it (from what I've seen). Maybe this future goof stuff is the way forward for CoD. Nice to see they've tried with porting this time round as well. Good job.
I was playing the single player last night. So far it seems like a really good port bar the lack of eyefinity support.
I've found a bug or too with setting up graphics options but once they are configured the game runs perfect.
A million times better than the cod ghosts experience.
I have not played the single player side of it but the multiplayer is smoother than Ghost's in terms of running it but the Peer To Peer server system has already killed, the game for me as the lag is just hideous.
I also cannot run it at 1080p, 1440p, 1600p or 4k at anything above 60fps unless I turn it all the way down to medium and the AA and HBAO off completly, and that is even with a overclock on my 3930k and a overclock on both my GTX780Ti's, I also took off the overclocks in case it didn't like it and the frame rate was just as bad.
Going to give the campaign a try now and see what that performs like.
I tried singleplayer this morning for 10 minutes...
All settings maxed pretty much and 2x supersampling.. didn't break a sweat? you sure everything's alright over there?
Haven't tried MP yet so I dunno if they're running differently etc.
The 91fps cap has been around for ages and i have no idea why. Maybe they want to diminish the movement advantages 125fps brings. In CoD4 you could at least change the fps cap.
Found the problem for some of the FPS issues, SLI is not working and on certain maps the frame rate plummets down to as low as 15fps when running in 4K.
After tweaking it abit though I am now running at 4K almost maxed out at a frame rate of between 80fps and 90fps, but the lag is still killing the game and the frame drops as well.
I found the frame drops where fixed by not caching the shadow option "the option to reduce load times".
SLi is in the new drivers that were released today.
Take it from someone who is strictly, and very vocally, not a CoD fan..
So far.. it's worth the punt (especially at £26 on PC)
In the LTT benchmark it did 65 FPS average (although that was mainly just walking around while nothing happened). This one gets a slightly lower score, but still decent at max settings:
https://www.youtube.com/watch?v=fAxjAPwplc0
If you look at the numbers running on that, the opening animation is running the GTX 750 Ti around the 98 to 99% range, so almost maxed out, and it uses almost all the 2GB of VRAM, and the GTX970 that is installed is just idling :huh:
*Edit*
I been playing it maxed out on the twins and it been handling it quite easily (apart from launch day with the textures and other bugs) but knocked the superscaling etc off and it runs flawlessly :D
