CableMod 90 and 180 Degree 12VHPWR Adapter Guide
Should have made one sideways too so the cables can run parallel with the GPU. Would allow you to wrap them around the GPU just like EVGA Powerlink design was.
I see a gap in the market Lazer RGB custom lighting effects you can now have a stage inside your PC Dice :D
I have looked into snowblind transparent side panel, but even to DIY something like that isn't cheap.
Yes, So much yes #winning !!!
:D
The snowblind side panel though IMO looks fantastic but then comes the issue of size, Taking up GPU resources etc... I'd say it's something really only for a showcase build that isn't meant for serious use.
This adapter must of cost Cable Mod only 4$ landed.
Don't know how they can justify a price of 39,99$
Hopefully the AliExpress adapters will be available soon :)
Yeah it's mad. I can get a full set of braided extensions for about £25.
