Does anyone know what the best case is for cable management, not only inside the case but to the rear to. One that has plenty of space so you don't get the bulging, can cable manage to the right, centre and left of back plate.
The cable management on the Phantom is pretty good. The way the door hinges into place makes it so easy to put the side on as well as opposed to the traditional hooks and slots. The Antec 900 however has to be one of the worst.
the fractal r3 was very very easy to manage lots of thoose things to put cable ties through, although the rubber grommets where always comming loose/off,
