Cable Extensions
Rekitoz
Hi I am just wondering if I would need any cable extensions for the corsair 780t, the power supply I am going to use is EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply.
Thanks
I'm going to say yes to this given the stats.
Cables:
ATX Cable 1x 600mm (m) EPS Cable 2x 700mm (m) PCIE Cable 4x 700mm (m) SATA Cable 3x 550mm, 650mm, 750mm (m) Four-Pin Peripheral Cable 1x 550mm, 650mm, 750mm (m) Floppy Adapter 1x 100mm AC Power 1x 1500mm (m) Modular Cable Type Full
Case external Dimensions:
Dimensions
637mm x 288mm x 602mm
Sorry the cables that come with the PSU are easy long enough to reach the required sockets within the 780t, I should have made my post clearer.
Ok so I went with the corsair ax 760. I was just wondering if i should buy some red/black cable extensions for the 24 pin mobo, the Gpu cable and the Cpu cable or if I should just buy some red cable replacements for those respective cables. If so which brand would be good in terms or price/quality. I do not want to replace every single PSU cable as it would cost to much.
The cable replacements would be better than the extensions less cables to manage as far as i know you would have 2 options the Corsair ones or the CableMod the CableMod ones are cheaper but they do come in Red/Back. TTL even did a video on both of the Cable replacements.
Hope this helps you.
what would be a rough estimate of the number of cable combs I would have to buy? And do I buy the E22 Black 24 Slot Cable Comb (Small) 3mm or E22 Black 24 Slot Cable Comb (Large) 4mm?
I think all i would need are E22 Black 24 Slot Cable Comb (Large) 4mm, E22 Black 12 Slot Cable Comb (Large) 4mm and E22 Black 8 Slot Cable Comb (Large) 4mm
