Building New Pc... How Does This Look?
Chiblake
Hey Guys
just giving you all details on a box im planning to buildits mainly for games and overclocking
can anyone tell me what could be better or better parts that may be cheaper in price etc
thanks for all your help
CASE VD4000BWS Thermaltake
CPU Intel Core 2 Quad Q6600 (2.4GHz)
MOTHERBOARD Asus P5K-Deluxe WIFI-AP Quad Core
RAM OCZ DDR2 PC2-9200 FlexXLC Edition 1GBx2
POWER Silver Power SP-1000E 1000W $290
VIDEO MSI GeForce 8800GTX Overclocked
WATERBLOCK Thermaltake TMG ND4 VGA Cooler
SOUNDCARD Creative Sound Blaster X-Fi XtremeGamer
HDD 320GB Samsung 'Spinpoint T166
WRITERS ASUS DRW-1814BLT with LightScribe
Pioneer DVR-212
Case - no good... look at lian li, silverstone, antec. Suppose it is personal choice, but you did ask
CPU waterblock - no good. (they make awful w/c parts) Try swiftech, fuzion...
Everything else looks pretty damn good :)
Also - forgive my bluntness, I'm about to leave work, rushing - you need a pump, reservoir, radiator, tubing, fluid and barbs and a grill to watercool. Oh and fans.
Thermochill make the best radiators... tbc
ok thanks
can u or anyone recommend the pc case and the water cooling kit to use also i plan to add another GTX later down the track and i want to water cool both of them
oh ok so the motherboard does not support 2 graphics cards... what motherboard is good for overclocking and supports sli
thanks
Personally I wouldn't bother with SLI if I were you. When the next gen nVidia and ATI cards are out you'll be wanting one of them (take it from me).
But if ya want SLI then Abit IN9 32x Max/Asus Striker Extreme/EVGA 680i SLI
Sorry a bit off topic; Kempez, how good is the EVGA 680i SLI? My bro just got one out of the blue with a quad core.
The best mobo by FAR for quad is the p5k. 680i's are OK for OC'in the quad.
Have there been many attempts with the IP35 pro + quads?
Ive seen plenty of P5k results but not many on abits:(
Ive seen plenty of P5k results but on abits:(
I'm confused!??
abit ip35 pro = p35.
asus p5k = p35.
Lots of people are using the asus due to the p5b legacy - awesome clocker.
Not seen any ip35 quad results BUT it is p35 chipset so SHOULD be same/similar to p5k.
I think abit make awesome mobos
i missed out 2 words for some reason...
Same chipsets often yield similar results, but there's a lot more determining factors that can put one ahead of the other by a long shot.
