LA_Hegarty
So I'm planning on a new build, I'll be using it for Music production & HD Video editing.
Here's what I have bought/have so far:
(From old pc)
Antec 900 Case With Power supply 430W
(From old pc)
DVD-RW Sata
(From old pc)
INNO3D GeForce 8600GT 256MB (Will be upgrading at later date)
(New 2nd hand) £85
Zalman Reserator 1 Plus Water cooling
With
ZM-WB5 Water Cooling CPU Block for AM2/3+
& ZM-GWB3 Water Cooling VGA Block
(New 2nd hand) £70
16GB Mushkin Redline DDR3 PC3-14900 9-10-9-27
(New 2nd hand) £130 Both
x2 Samsung 128GB SATA 3 Gb/s (Raid 0)
This is what I'm planing on buying to go with that lot:
one of the following M/B's?
ASRock 990FX EXTREME3 (AM3+) £85
specs sort list
3 x PCI Express 2.0 x16 slots
DDR3 2100(OC)/1866
Sata 6Gb 6x
USB 3.0 2x
1394 None!
Full http://www.asrock.co...=Specifications
ASRock 990FX Extreme4 (AM3+) £130
specs sort list
DDR3 2100(OC)/1866
Sata 6Gb 8x
USB 3.0 4x
1394 x2
And one of the following CPU's most likely the cheapest for now!
AMD FX-8150 Eight-Core, Passmark: 8,243, OC 9,676
AMD FX-8120 Eight-Core, Passmark: 7,085, OC 8,900
AMD FX-8100 Eight-Core, Passmark: 6,508, OC ?
AMD FX-6200 Six-Core, Passmark: 6,480, OC 7,027
AMD FX-4170 Quad-Core, Passmark: 4,759, OC 5,460
AMD FX-4100 Quad-Core, Passmark: 3,984, OC 4,774
(Thinking of going for this one as there's one online for £65 & all the others are £100+, leaves room for a future upgrade)
Don't really want to spend any more then £200, already spent £285 + the parts I had case etc..
What do you think?
LA.
(From old pc)
(From old pc)
DVD-RW Sata
(From old pc)
(New 2nd hand) £85
With
(New 2nd hand) £70
specs sort list
DDR3 2100(OC)/1866
Sata 6Gb 6x
USB 3.0 2x
1394 None!
specs sort list
DDR3 2100(OC)/1866
Sata 6Gb 8x
USB 3.0 4x
1394 x2
What do you think?
LA.
