Building a desk!
siravarice
Not strictly PC components, but there will be some involved!
After seeing stepster post a beautiful looking desk with a computer integrated into it with all custom watercooling and neon lights, I plan to build my own desk of similar ilk.
It won't be watercooled and have all fancy lights, but it will have TWO integrated PC's and should look pretty special.
So if anyone knows where I can get 10mm Sheet acrylic (2000x1000mm) I would be very grateful.
The desk will simply be a rectangle, and if made from decent acrylic, should be pretty easy to make, the only trouble will be with the legs and supports. I know it sounds crazy but I've been wanting to build something for ages now, and this seems like fun!
It would probably be easier and just as cheap to use glass. It would look so much more sexy to not to mention it wont scratch as easy as acrylic.
Get a piece of acrylic throw some tiny dust on it then put your keyboard and mouse on it and slide it around, It will scratch easy.
