Greetings! I wanted to share my new build as it comes together, both from a parts-list perspective as well as conceptually, as my specific goals and plans inevitably bow to design necessities and a better vision of what it can eventually become.
I haven't built a PC for myself in quite some time, and when I did, there were always constraints, most frequently budgetary! I also never water-cooled my builds, mostly because I wasn't willing to risk leak damage on top of budget woes. this build will still have a budget ceiling, but it will be generous. I still have that bias and fear of leaks, and that will be a primary consideration in this build, as you will see.
I also resent dust in my cases, heatsinks, fans, etc. Unfortunately, I am not keen on the constriction of intake filters, not to mention... they get dusty as well, and right quickly!
I will share the specifics of how I intend to deal with water cooling and dust control as I approach those elements of the build. I want it to have some shock value and appreciation, as while there may be nothing truly unique these days, this build isn't quite like anything else I have seen.
Concurrent with the PC build I will also be building a PC gaming desk, and a separate cabinet for the PC hardware. Mission Control, Battle Station, Bat Cave, not sure what to call it but you get the idea, I hope.
This is not a great time to be building a High End PC, in my opinion. AMD has made amazing strides in the past year, but isn't quite there yet. Intel got shook, but not hard enough to stop over-segmenting the CPU market, and holding us hostage to features like PCIe lanes, proper Raid, and CPU thermal solutions that seem designed to require you to void your warranty. Other manufacturers seem to be taking the path of least resistance in the hope that all the RGB glare will blind us to the the lack of innovation, quality control, and customer support that has become the norm. Predictably, my build parts list has changed repeatedly. I almost chose Ryzen as a place-holder for newer tech upcoming, then Threadripper for cores and PCIe lanes, and then the Z370 platform as a better place-holder... and then the RAM shortage and Crypto-mining craze hit. I almost threw in the towel. Maybe I still should, but here is my build list, still subject to change, of course!
CPU - 7900x, Delidded, binned for 4.7GHZ. Shipping as I type.
Mainboard - Asus ROG Rampage VI Apex. Sitting next to me, glowing. Aside from all the obvious reasons for this particular board (Designed for OCing, robust VRM and cooling, Etc...) I am really keen on the Dimm.2 slots. I do not intend to have any spinning drives, and if I don't have to "glue" my drives to the mainboard surface, bonus!
GPU - EVGA GeForce GTX 1080 Ti SC2 Hydro Copper GAMING. In shipping. It was available at EVGA site for nearly MSRP, btw. Not shilling for EVGA, but with current GPU pricing and availability, this is a place you should at least be looking. Stock changes frequently, so look multiple times.
RAM - G.SKILL TridentZ Series 32GB (4 x 8GB ) 3200 Timing 14-14-14-34 I wanted non-RGB. I wanted decent timings. Like everything else on the list, I didn't want to pay this much. Dead horse.
SSD - SAMSUNG 960 EVO M.2 1TB NVMe (X2) No spinners, thank you. I will be Dual booting Win10 and Solus. (Sublime linux distro) I like my OSes on physical partitions, not logical.
PSU - Seasonic PRIME Ultra 1000W 80+ Platinum. Pending, still open to suggestions here. This is slight overkill, but even if the entire build wasn't that way, I like my PSU to to have headroom in it's designed duty cycle.
Cooling - Still up in the air as this is my first shot at this.
CPU water block - EK-FB ASUS ROG R6E RGB Monoblock In a build with no/minimal RGB, this should look menacing, and I will sleep better with this securing the 7900X.
Radiator - EK-CoolStream SE 560 Nominally overkill as well, but due to the realities of the cabinet I am building, this was the way to go.
Reservoir - EK-RES X3 400 800ml See above, lol.
Pump - EK-XTOP Revo D5 PWM This should do the job, but suggestions please. I need good flow, quiet operation. This will not be pumping any great distance "uphill", as it likely would in a full tower.
Coolant - Yes. Don't know a damn thing here, other than what I don't want.
Spotswood Large Tech Station - An extruded aluminum (I am American, deal with it = ) open frame tech bench for the PC. This will be used as a starting point for mounting my PC within the cabinet I am building. Main difference in my build is that it will not be two layers like this shows. All my components will be on the same level.
+ tons of the expected cables, wire management, Cable Chain, etc.
Ossic X - 3D headphones. If you haven't heard of them, you will. Expensive, but fully 3 dimensional positional audio. Not stereo, not 7.1 emulated dolby, positional in 3 axes. (as in axis, not hatchets. Funny story, I am related to a famous hatchet-wielding murderess, but back on topic.)
Keyboard - Roccat ISKU+ Force FX I do not use a keyboard to game so this will be an adventure. but, this board has key-binding synergy with my mouse, so we shall see.
Mouse - Roccat Tyon See above.
More to come, obviously. My apologies if this ends up being a duplicate thread, but my original thread disappeared when I tried to preview it in advanced editor. Stuff like this just happens to me, so stay tuned, the build might take strange turns. = )
