name='Toxcity' said:Hiya guys.
Just a quick question:
If I was to rip my XP dics to harddrive on the server, could I boot from it to install XP on other PCs on the network?
Thanks!![]()
name='XMS' said:If you wanted to install Windows from a network share on a server you'd need to create a custom bootdisk that contained DOS drivers for your network card along with all of the MS networking drivers.
Some can be found here http://[SIZE=-1]www.bootdisk.com/
Or just install Windows from a USB stick instead
[/SIZE]
name='Toxcity' said:Thanks for the quick reply dude!
Right, network booting looks like to much work atm.
Could I boot from a USB harddrive? Could be good.
If you can't, I will have to buy a bigger USB stick for Vista!![]()
getusb.info said:Run CMD.EXE and type the following. WARNING: This set of commands assumes that the USB flash drive is addressed as “disk 1″. you should double check that by doing a list of the disks (type “list disk”) before cleaning it. If you have multiple hard drives, like an SDFlash drive or a Multibay drive, you could end up wiping your second drive using this command.
1. diskpart3. Copy Windows Vista’s DVD ROM content to the Flash Drive
2. select disk 1
3. clean
4. create partition primary
5. select partition 1
6. active
7. format fs=fat32
8. assign
9. exit
Simply issue the following command to start copying all the content from the Windows Vista DVD to your newly formatted high speed flash drive.
* xcopy d:\*.* /s/e/f e:\
And that’s it. Boot up the machine, have it boot off the USB drive, and watch how fast the installation completes.
name='Toxcity' said:Cheers XMS, Ill give it ago.
How big is Vistas installation files? 2.4gbs?
name='pinkpig242' said:m8 upload it cause i dont wanna download 4.5gb and get 3 gig of crap![]()
name='pinkpig242' said:shhh m8 know one will know - delete both our conversation and they wont find anything![]()
name='XMS' said:Talking warez to a forum admin isn't generally a good idea.
Thanks!![]()
name='llwyd' said:I might get the old VLite on my copy of vista, i might be able to claw back a bit of performance
name='Toxcity' said:When I get Vista running I will use Vlite!![]()
Yep.name='Toxcity' said:XMS, are USB sticks faster than CD rom drive?
