Boardy's Mach1
Status
Not open for further replies.
boardy
Here's my rig.
Finally sorted the cathodes in it and the clear side panel on the Mach1 which I think makes it look pretty sweet.
My specs are :
AMD Barton 3000+@2745Mhz@1.8v
Abit NF7s v2 BIOS 19
MSI GeForce FX5600XT 256Mb
Creative Audigy 2 Platinum-EX
6.1 Digital Surround Sound
120Gb Seagate Cuda
Matrix Orbital LCD Display
Enermax 465W PSU
Waterchill on NB
Mach 1 CPU cooling
What you guys recon? Gd/Bad Points, I want to make this system the best it can be.
Cheers and hope you like it
Boardy
That looks superb mate. Kudos to you. I think I will look into cutting a window panel in the aluminium rather than just leaving the panel off - but it does look good. You should get some Lian cd bezels too, just for aesthetics.
boardy said:
Here's my rig.
My specs are :
120Gb Seagate Cuda
Enermax 465W PSU
Waterchill on NB
Mach 1 CPU cooling
Boardy
AS phil said yeah i think u should make a proper window in the aluminium which is gonna look better...
Try and get rid of the neons and get some cold cathodes :).
Sleath your drives and get an alu sticker for your MO lcd...your case will look a lot better then i reckon and youll love it.
Great effort there mate :).
Nice looking rig
well done :)
Cheers guys.
Been stealthing the drives this weekend actually with the bay covers so now looks like theres no CD-Rom in there at all. I'm actually getting a new MO LCD soon, thats the one from my old rig which I didn't really want to get rid of.
Try and get rid of the neons and get some cold cathodes.
They are actually akasa cold cathodes, not too sure about the UV one being in there though.
I actually replaced the alu side panel with clear perspex, thinking about getting the alu panel cut but not sure yet as I'm probably selling this unit soon so I'l get the new one cut I recon ;)
All in progress, all I need now is decent airflow to my water rad which is causing a prob atm. Its behind the 2 front fans but only 1 of them seems to get any air into it and that has a huge dead spot in the middle. Any suggestions welcome :)
Cheers Boardy
Status
