Blue tooth in Win7 [Dell Laptop]
mwvirk
hi
i have dell inspire 1525 and just installed windows 7 RC but i cannot get blue tooth icon in notification & control panel area even i can see that blue tooth light is not ON - is there any driver problem? in device manager, everything is installed and there is no warning/error etc
need help ASAP, its my office laptop and i want to install blue tooth devices on it.
thanks
i don't have any usb device other than 1 ext HD. all device in laptop works fine and ther is no issue with anything - only thing is that i cannot see blue tooth in notification area/control panel area/device manager panel
looks like that blue tooth is not installed at all but in device panel its not showing that blue tooth is not installed.
thnx
the first time i installed my criago blue tooth dongole i had to go to the start and open the utillity then select show icon in tool bar. mine was plug and play in vista 64 my friend ordered the same as i have and in 7 he had to do the same. you my need to reboot. do you have a multi boot if so boot into vista partion
