Blue screen if using 2 screens
Hi
I've been having an issue with my MSI GTX 780 Gaming for some reason if I connect a second monitor my system blue screens then the display switches to the second screen and the main screen has no signal :confused::confused:
someone please help
My Monitors:
Screen 1: Samsung JE32C530F1W 32" (HDMI)
Screen 2: Old Tatung L5CTT 15" (VGA)
My System:
i5 4670k
MSI GD-65 Gaming
MSI GTX 780 Gaming
Corsair Dominator 8GB 1600 Mhz
Kingston HyperX 3K 240GB & 120GB SSDs
Seagate Barracuda 2TB HD
Corsair RM 750
I dont think a 780 even has a analog video output does it?
You certainly shouldn't be using anlong with a high end card like that.
Try a different nVidia driver or re-install the driver and see if that helps. See if you can get the error code from the BSOD.
How do you have them connected? both to the gpu or do you use the intel hd for the secondary? I use the iGPU on mine and it works brilliantly, might be worth a try.
