Henrik
After running my LGA775 with a QX9650 for almost 3,5 years I finally decided to upgrade.
I had nothing but trouble with my 790i board and was very tired of it. I kept getting random
freezes in windows which i managed to iron out after more then 2 years.... Due to the 790i
being picky about RAM. Well enough about that....
Link to my old rig: http://forum.overclock3d.net/showthread.php?t=37355
Specs:
CPU: Intel 3930k @ 4,6Ghz 1.304v
Motherboard: Rampage 4 Extreme
Ram: Crucial Ballistix 1600Mhz 4x4GB
GPU: EVGA GTX580
Case: 800D
OS Drive: Corsair force GT 120GB
Cooling: Water on CPU, Heatkiller 3.0
I cant be more pleased with the 2011 platform, haven't had a problem yet. And the 3930k was
very easy to overclock, almost too easy for my liking haha
I currently have the CPU running @ 4.6Ghz with 1.304v under load. Which i guess is a good
voltage for 4.6?? I have Disabled SpeedStep and TurboBoost so its running 4.6 nonstop.
Ram is currently at 1600Mhz but I think there is room for more, will give it a go when I have time..
I have been running watercooling for 2,5 years now. When i went from 775 to 2011 I got the mounting kit
for the Heatkiller, new tubing and liquid. When I was finished filling the system with water I noticed two
leaks, they where from two of the 45 degree fittings. (I quess the O-rings inside the rotating part of the
fitting get dried out over time??) So i got new EK fittings.
Cooling Specs:
CPU Block: Heatkiller 3.0
Radiator: ThermoChill PA 360
Tubing: 1/2" ID - 3/4" OD Thermochill (clear)
Coolant: EK-Ekoolant Premixed Blood Red
Fittings: EK 45 degree adapter and compression fittings
Pump: Laing D5 Vario
Enough with the typing lets get to some pictures.
The old leaking fittings....
You can actually see two red drops on the paper under the CPU block and under the res..
The new EK fittings
The new EK fittings
After some leak testing she is done! The two LED strips are connected to one of the ports on my fan controller so I can dim the lights down when gaming in the dark
ATM i don't have the camera but when I get it back I will get some final pics for you guys.
Swedish viking over and out!
Specs:
GPU: EVGA GTX580
Case: 800D
Cooling Specs:
The new EK fittings
The new EK fittings
