Edgeyforsure
im not sure if this is the right section, but im wondering how you guys do / dont block off unused fan grills, atm i have been using brown parcel tape for the past few weeks, and dust inside is ALOT less than before (i live in an old house with floorboards
) wondering if there is anything more pretty looking than brown parcel tape... as atm my rig looks pretty silly.
only reason i want to do this is because the front of my pc case is dust filterd, however the vents that arn't exhausting are sucking in air + dust
atm with my case, nzxt m59. i have two front fans intaking, one 120mm infront of the HDD's and one 120mm zip tied inside the 3 spair drive bays
i have the rear fan exhausting and the side fan exhausting hot air from the gpu, however the top two fan mounts are sucking in air as atm the exhaust fans push more air than the intakes (coolink swif2 120 p) running from pwm for the exhausts, and 2x nzxt white LED fans up front.
to cut it down to a sentence
was wondering if there was anything you could buy to block off 120 / 140mm fan mounts?
