Black n Orange NZXT Phantom
Robopolo
Recently built this for a friend, not too sure on all parts but its a quick list
i7 3770k
ASUS Sabortooth Z77
Corsair H80i
2x 1TB samsung sata II harddrives
2x 8gb Corsair vengance 1600mhz ram
Corsair TX850M (NOT FUN TO CABLE MANAGE BTW)
NZXT Phantom full tower case
ASUS GT560
its not finished yet still sorting out cables and we've had a couple of hardrive issues but nothing we couldnt handle :)
The orange motherboard tray is a little bright for my tastes, I'd HAVE to paint it. Other than that it looks clean.
Though, is there a reason you're using the cable management holes on the far side of the motherboard, rather than closer?
i like it . i would run the sata's and motherboard power through the nearest grommet rather than going to the next one over, just for a cleaner look. not a big deal though. the orange is a nice change from the usual colors. i like the contrasts on the trim outside the case and the motherboard tray area.
See the psu's thick braid doesn't allow enough bend so the USB 3 n 24pin could only go though those holes n instead of having half te cables through the closer ones I though it looked more uni form going all through the same set, ps this case doesn't allow a lot of round at the back for cable mangement, well not for non flexible thick braid anyway
