VonBlade
Hi lads and lasses.
Gigabyte MA790X-UD mobo. 7750BE processor. 2x2GB Corsair 8500 DDR CAS5. ATI4850.
Installed everything fine and dandy. However I can't install Windows. You might consider this a small issue, but that's really the start of it.
Sometimes it wont let me into the BIOS screen.
Sometimes it will, but the keyboard doesn't respond.
Or the keyboard responds initially, then doesn't.
Sometimes I can get to the XP setup screen but it's Sloooooooooooooooooow (huge pauses before it does anything).
Sometimes I get all the way to "Setup is starting Windows" and the monitor powers off (like a sleep state).
Sometimes it sleeps during the copying of the setup files.
Sometimes it never gets past "press F6 to install RAID".
I've upped the RAM voltage from 1.8 to the 2.1 Corsair state.
I've tried both sticks in 1 and 2. And both sticks in 1 and 3.
I've tried one stick in 1 and 3. I've tried the other stick solo in 1 and 3.
I've tried @ 1066 and 800.
I'm totally out of ideas. Any help, or clue, would be hugely appreciated.
The only possible thing I can think of is that my PSU only has a 4 pin power connector rather than the strange 8 pin chappy the mobo needs. But according to Gigabyte and the few things I've read online it'll be fine with 4 pin.
Or, as was the case with my old memory, the memory is FUBAR.
Please. MrsVB is gagging to use it and I'm desperately out of ideas.
VB
VB
