My new Bitfenix Prodigy build.
The build is as my sig but will list fully.
The build is a complete new build pretty much after having the Corsait 600T SE White , which while being a very nice case visually and to build in but just too big for what I needed, so did some trade ins changes and bargain hunting and got this little package.
Forgot to add havent got around to screen caps of my temperatures yet, but using Core Temp for the cpu it sits idle at around 35 and the most I have seen it hit was 62 that was under full load in Prime95 (CPU is NOT overclocked yet)
GPU temperate seems very stable also under full load in Heaven benchmark max temperature was 68 with the default settings left on in 1920x1080.
Fan noise is quieter than my 600T but not silent (which is what i was hoping for).
Cabling isnt final yet, want to let the machine run for a couple of weeks and be sure everythings fine before i start with mopre serious cable management.
- Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W)(£170)
- ASRock Z77E-ITX Intel Z77 (£120)
- Kingston HyperX Blu 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit ( £36)
- Powercolor Radeon HD 7970 V3 3072MB GDDR5 PCI-Express Graphics Card (£270)
- Corsair Hydro H100 Extreme Performance Liquid CPU Cooler (£75)
- Corsair Professional Series AX750 High Performance 750W Modular '80 Plus Gold' Power Supply ( £135)
- Corsair SP120 Quiet Series High Pressure Low Noise - Dual Pack ( £18)
- Corsair AF140 Quiet Series Low Noise High Airflow - Single Pack X 2 (£15 each)
- BitFenix Prodigy Mini-ITX Cube Case - Arctic White (£65)
- BitFenix Recon Internet-Connected Fan Controller (White) (£40ish)
- Samsung 250GB SSD 840 SATA 6Gb/s Basic (£105)
- Western Digital Caviar Green 3TB SATA 6Gb/s 64MB Cache - OEM
