Bitfenix Prodigy "Mirror"
ArtX38
Systems:
BitFenix Prodigy (white)
Gigabyte GA-Z77N-WIFI
Intel Core i5-3570K
Corsair Dominator Platinum 2 x 4GB
EVGA GeForce GTX 670
OCZ Vertex 4 128GB
WD Red 3.5'' 2TB x 2
OCZ ZT Series 650W
Water systems:
Watercool HEATKILLER® CPU Rev3.0
Watercool HEATKILLER® NSB Rev3.0
Watercool HEATKILLER® GPU-X³ GTX 670
Phobya G-Changer 120mm
Koolance 240mm 30-FPI Copper
Laing DDC-Pumpe 12V DDC-1Plus
Phobya Laing DDC top Black Nickel Edition
Phobya Balancer 250 Black Nickel
Phobya Temperature Sensor In / Outer Thread G1/4 x 2
Koolance Nozzle Single, 3/8" (10mm) G1/4 Angled Threaded x 3
Koolance Nozzle Single, 3/8" (10mm) G1/4 Threaded x 3
Masterkleer Tubing PVC 13/10mm (3/8"ID) UV-reactive Black
Masterkleer Tubing PVC 13/10mm (3/8"ID) UV-reactive White
Mayhems "Aurora" - Supernova Coolant
Other:
BitFenix Spectre 140mm Fan- white
BitFenix Spectre 230mm Fan - white
BitFenix Spectre 120mmFan - white x 3
NZXT 24-Pin ATX
NZXT 4-Pin ATX12V
NZXT 6-Pin PCIe x 2
Aerocool Touch 2100 Panel
RGB Led (60 Lighting effects)
I see you're using an OCZ PSU. I would ditch that IMO. OCZ is probably one of the most unreliable brands there are atm. Also, mayhems coolant is fine. Though it seems to have issues with tygon hosing. And FTR is right about the Aurora.
Before I forget: I really like what you did with the prodigy mate!
Then what do you recommend ?
Depends on the color you are planning to use. I mean i dont want to drag Mayhems in the dirt but there are diff. opinions out there on their products.
Personally i had a bad experience myself with the combo Pastel/Masterkleer.
Have a look at mayhems pastel :)
Mayhems is great though, I think you should use mayhems.
Though aurora will clog up your loop after a while.
EDIT: Just saw the above. I'd have a look at some reviews mate :)
WOW :drool:
Awesome job there mate :D
May i ask how you did the mirror effect? :rolleyes:
Maybe its some special film that you apply on your sidepanel window or some kind of special glass that lets the light pass only from one side ??? (like in a police station when they question suspects)
IDK ???
Would love to know myself.
This build... wow. I simply love what people are doing with this case. I don't think BitFenix foresaw the flood of neat builds that would arise from this thing, and this one is certainly no exception, looks stellar!
What kind of mirror do you use?
Glass + mirror window films. If you not know or not pay to do it (it is better to refer to specialists, save your nerves and health)
Inappropriate, plexi, organic compounds, or other substitute! Only the original glass (window) a minimum of 4mm. It is advisable stained 20-40%.
Tests were carried out with all kinds material (in all cases, very bright visible micro scratches) fits only glass.
(Sorry for bad English)
Test EVGA OC scannerX / EVGA Precision X
0_a6fcd_33daa6c4_orig
FurMark SressTest 15min.
0_a70c4_b14bde50_orig
3DMark Vantage Extreme
0_a70c3_c183f130_orig
