Biostar 8800GT
louistheron
Hi there
Firstly my specs :
CPU:Intel Q9550 CPU
Motherboard: Intel DP35DP
Memory: 4GB DDR 800 Corsair.
PSU: Cooler Master 650W
Operating system: Vista Ulit x64
My problem is that I'm experiencing is a low score in 3D mark 2006. With latest updates and hot fixes..
I'm getting 7706 Points. And according to allot of web sites I should get in a range of 11000 up.
Any help would help thanks allot.
Yeah.. Well... Erm... I didn't see xD
Do you have your chipset drivers installed? And how long have you tested after Vista booted?
Card
I boot up the system and wait for the system to Idle the I bench.
All my drivers is installed. I did test the card on other PC aswell same thing. :-(
Nothing overclocked. Just normal. I tested it in PC thats got a 8800GT in that scores 12k+ ..Put my card in does not go past 8k.
Keep GPU-z running during 3dmark and check the temp graph afterwards. I guess throttling starts around 90*C.
Btw: try saying everything in one post. If you forget something, there's a nice little 'edit' button at the bottom of every own post.
