BIOS Update Asrock N68-S3 UCC
PandaDNB
I have a fairly old PC and since I can't afford a new one I'm trying to get the most of it and I heard that updating the BIOS can help that. My current BIOS version is 1.30 and as you can see on this page there are different versions. My question is if i download "1.60 Update CPU code. Windows®" will there be any problems/compatibility issues ? My CPU is AMD Athlon II x2 250 3ghz (oc-ed to 3,45)
Here is some info you may need in the form of pictures:
http://prikachi.com/images/827/6551827V.jpg - CPU
http://prikachi.com/images/839/6551839U.jpg - Motherboard
More you can read on the asrock site that is mentioned above.
You should be fine with the update.
However the 1.6v wont give you any boost to your current configuration.
from 1.3 - 1.6 they only added new cpu support + Cpu core unlocking .
Your current cpu does not support any core unlocking, unless you are thinking about upgrading your cpu, the bios update wont give you any boost.
AFAIK.
