bh5 doing 275fsb 1t 1:1 2-2-2-5
name='GoLLuM4444' said:
Wow nice. What rating is the bh5? Also what sort of superpi ad pifast times do you get with that?
as far as i know its winbond bh5 bought from my good friend shigs......
problem is its only 2x 256 meg........ get my ocz vx pc4000 tomorow
will push it to its limits and see what fsb stable i get with them.....
told u that stuff rocks mate, thats the exact same ram i was usin when i took ur crown in 3dmark01 ;) lmao :D
**waits for dazzies pimp slap**
lmao
If I weren't up to my ankles in ram I'd go and start a Wanted: OCZ PC4000VX thread right now. I'd better sell off some of my other stuff first.
mrbios said:
what voltage have you got through it there? some VERY nice ram indeed
oh um, nice wallpaper ;)
pushing 3.6 volts in there using 2x sunbed big silly fans blowing inside my case....... dont tell the wife..... big big electric bill lmao......
this is the bh5 i got from shigsy m8.....
As the.M says using the half multis means your RAM isn't running at the speed it looks like it is.
Your 287 is actually:
287 * 7.5 divided by the closest whole multiplier (8) = 270 FSB
ibby said:
3.6 .. only
get 4 into it ;)
get extreme man,
4V don't do nothing! I got a stick of 256Mb bh-5 that is 100% stable with only 3.68V... When I go over 291 it just causes major crashes even with 4.05V which is sad because I want to try 300 2-2-2-5 stable. The memory has 2 80CFM delta's blowing at it so its not a heat problem.... I have a feeling it's the memory controller crapping out, I don't think they can handle those timings with such a high clock!
Cheers
