BFBC2 crashes my pc hard
SeekaX
i'm playing bfbc2 on this rig for a year now and a week ago bfbc2 started crashing my pc. and it's the ugly kind of crash. freeze and i hear the "something is terribly wrong" buzzing noise from my headphones, all i can do is cut the power and restart. i had to reinstall windows anyways, so i did that and installed the drivers which worked perfectly fine 2 weeks ago and the same error occurs. so it's not the software. my gpu is overclocked, but it has been like that for half a year now, it's definitely stable since not even far cry 3 or any benchmarks make it crash. any ideas?
I have quite similar rig specs, ive had same issues, its the OC, bc2 is very sensitive when it comes to OC as it often likes to max the cpu load to get most amount of fps, one solution is to turn oc down or make it more stable.
or use vsync to keep those frames on a leash.
bf3 is quite similar in that aspect as well but it doesn't crash. tip for oc, it may be bench stable but thats not always the case in game scenario.
mate i've been using that oc for half a year and never any problems occured. and last week out of nowhere it just started crashing. i will try downclocking though
Reset the CMOS, and all overclocks on the graphics card too.
Worth a try, if still happens you can rule out overclocks being the issue.
reduce the overclock or turn off the onboard sound,its an old bug that they never bothered to fix and still happens with BF3(dice are too lazy these days)
100% not the overclocks, went back to stock on everything and same thing happened. i read something about onboard sound problems but why would it start 1 year after the rig was build. also turning it off isnt really an option because then i dont have any sound.
