Best white case for air cooling
thathard
I am looking for a white colored case for an ATX build I will be doing but I will not be water-cooling anything I would like to keep it under $200(in US so we use $) but I am willing to pay more
I have the Phantom in red and its a great case, you can now also get it with a red stripe...
Also there is the CoolerMaster CM690 II...
It depends how good you are with a dremel/jigsaw, another nice case in white is the Bitfenix Collosus.
There are non window versions aswell that i personaly prefer more than the windowed versions of them.
Seen a windowed side panel available on Scan recently, best of both worlds.
Ty and is hard to add a window to the phantom?
Take a look at what this guy did with his phantom to give you an idea.
The colosus isnt great for aircooling tbh. and neither is the phantom tbh. not when you want to get really picky.
The BEST white air cooling chassis is the RV02 White Raven from Silverstone. Its farking epic.
Indeed the white raven is probably the best case for air cooling. Actually ordered one today. Not sure what I am going to put in it yet, but I had to have the case. Might even go taboo and watercool it
What makes it farking epic?
3x180mm Silverstone Penetrator fans intaking from the bottom of the case chucking in plenty of air without anything blocking the airflow. Penetrator fans also have high static pressure so they are able to push the air straight up and past obstacles. Since the motherboard is rotated 90* the airflow is also supported by the fact heat rises.
Also the case looks epic imo and fully dust filtered.
The only thing that might beat it is the Silverstone FT02 due to it being aluminium, but that only comes it black and silver.
Farkin' epic physics! That's why.
Don't forget, you'll be looking for the RV02-E or FT-02 for the same internals, the RV02 had some more build niggles.
Being the owner of a Phantom I totally agree with this. It took a lot of modding to make it a good air-cooling case. But even then the White Raven is much better. And I love the unique design, it really stands out.
