E Elven New member Jul 6, 2007 #1 Hi all I am after knowing what is the best AV/Firewall cost options are not a problem
N nathan New member Jul 6, 2007 #2 name='Elven' said: Hi all I am after knowing what is the best AV/Firewall cost options are not a problem Click to expand... i'm still a big fan of nod32. I only use the AV, but you can get a security suite. www.eset.co.uk EDIT: i think you can have a 30 day trial of it too. worth a try!
Rastalovich New member Jul 6, 2007 #3 name='nathan' said: i'm still a big fan of nod32. I only use the AV, but you can get a security suite. www.eset.co.uk EDIT: i think you can have a 30 day trial of it too. worth a try! Click to expand... Only one I`ve found so far that is possibly good enough and doesn`t slow the system down.
E Elven New member Jul 7, 2007 #4 Right so NOD32 for AV, whats best for firewall I use Zonealarm on my XP install but wondering if it works for Vista.?
F FarFarAway New member Jul 7, 2007 #5 There is a Vista version available, yes It sucks, but it is available
Rastalovich New member Jul 7, 2007 #6 Ya ZA suite for the Vistan isn`t a nice experience. I`ll keep retrying the releases tho to see if it improves.
E Elven New member Jul 7, 2007 #7 What firewall do you guys use then on Vista for stability and security? got NOD32 going now so just using the inbuilt firewall system for now.
I ionicle New member Jul 7, 2007 #9 zonealarm 7.0 AVG Free Lavasoft adaware spybot search and destroy and nod 32 aswell
