best UV lights for coolant
The question is a bit vague, it depends what you want the effect to be like.Generally speaking cathodes give a uniform illumination along their length, leds are point sources and so can pick out individual parts or be inserted into waterblocks, reservoirs etc.
im using the NZXT switch 810 i plan on using multi coloured leds with a control.. but i want the UV effect for my feser 1 coolant.
i really just want it to illuminate the tubings so i will most likely put them along the sides of the case inside...
i just have problems finding a good set of them... and also choosing
I would personally recommend something like the Phobya FlexLite in UV over UV cold cathode's due to not having to hide the inverter and the fact that they are flexible so can bend round corners in your case. I would also make sure they are hidden from view though to get the best effect. However if you wish to light individual elements with UV I would get some individual UV LED's. Hope this helps.
