best sr2 case
thathard
So I have the honor of doing a Sr2 build but a can't pick a case. I don't like cube cases at all, I would like it to have a window or can be easy moded for a window. Also needs to fit 2 360 rads and look cool.
they even have windowed versions now
as ttl said it can be modded to have a front 480 rad... http://www.overclock3d.net/reviews/cases_cooling/xigmatek_elysium_video_review/1
the clips for the front rad are now available directly from xigmatek
i have this case
EDIT: it will house my future WC'd terramar-BD 24-core (2x 12) rig in Q1 2012
Best case for the SR2 is from caselabs.
If you have the money for an SR2 and the Xeons needed then you can afford to spend more than the 150quid the Elysium costs.
Caselabs all the way.
That "small" Case Labs case video is so intense that Trudy's Personal Supercomputer and rad box could be contained in that one tool-less access case.
I would like to see a review of the Cubitek HPTX-Tank case, its a budget full aluminum tower and i think it worth a good looking at its features and what can be done with water cooling as wheel.
