Best PC Microphone
I'll upload a video comparison of what the microphone sounds like when I get the time/get home. My mic died on me a while back otherwise I'd do a comparison.
TBh I'd just get the snowball, they're decent for the price although I hope you will avoid having background noise.
Thanks, Tell me when you have uploaded it.
I looked up some reviews on the Blue SnowBall and apparently you have to be extremely close to it like 5 cm away because the vocal noise it picks up is low and i need something about 5" away from my mouth so is it still the best choice?
If you are 30cm away from the mic, and it's not a high quality product, you'll get background noise out the wazoo.
Please don't multi post, we have an edit button so you can go back and edit your previous post. I have merged these two together for you.
Sure thing, Thanks for telling me i'll do that next time
I'll probably go with the Snowball as most reviews says that the best option for the price range and audio quality - Do think ill be able to pick one up on eBay for about £30-£35?
