Best method for draining?
Roverno
Hi all,
Im having to redo my WC loop because the tubes i bought are going yellow with the mayhems white fluid i used. While i do it i would like to put in a small ball valve for draining the loop much easier. I have looked and found that bitspower do do ball valves but i haven't found anywhere that i can actually buy them.
I need it to be black because i am very picky about my pc.
P.s also looking to get some black o-rings for my bitspower compression fittings.
So whats the question? If you are asking where then tbh google can tell you. If you are in the UK then youll have to import them from outside.
