I ikduncan New member May 15, 2007 #1 looking to improve on the stock cooler. was thinking about a Scythe Ninja can get for around £22 delivered ?
I ikduncan New member May 15, 2007 #2 is it worth it buying the SilenX Ixtrema 120? and if so which one? can i strap the 90cfm 35mm one on the side ok?
I ikduncan New member May 15, 2007 #4 any idea about fans though, i hear the stock cooler isnt great? and silenx are the ones to go for but they do a 25mm and a 38mm which to buy?
I ikduncan New member May 15, 2007 #9 CFM doesnt seem as high? is it any better than the stock scythe one? seems too cheap?
R robump New member May 15, 2007 #11 theres loads of reviews heres a few on just the yate loons, review 1 review 2 I read one somewhere that cpmaored loads and it still said the loons were the best. Hope this helps Rob
