Best case £100?
Pat123
As stated in the title, what is the best case for £100'ish? Don't really want to spend much more. Needs to take a NH-D14.
Thanks in advance guyss
The Corsair 400r is AWESOME for the price, only one problem that is actually Corsair's fault: front panel cable management... They either have to run through the grommet, or run down through the 5.25' bays, then you cannot add any optical drives, WC bays. Otherwise I LOVED it
Corsair got that 500r in white also. Very nice case.
Check out the Silverstone TJ08-E. Its for m-ATX MB's, but the NH-D14 fits. TTL have done a review on that one.
Yup, the 500R is a fantastic looking case if you're looking for the standard ATX mid size cases. Tom did a great review on the TJ08-E, which you may take a look through also.
I'm quite taken with the understated BitFenix Shinobi (with/without window) this will happily accommodate a Noctua NH-C14 with both fans fitted. Secondary fans in the case should keep interal temps low.
Cheers guys, I was having a good look at the 500R just unsure about how prominent the bulges on the sides are? Other than that I think it has me sold.
