seumasbeathan
Banned
Hey guys, I am going to be upgrading to z77 soon and I was just wondering what you guys would consider to be the best budget mobo.
At first I thought that I would go for the MSI Z77A G43 as msi seem to be the best for z77 atm but then I looked at some reviews etc and found that especially when it came to overclocking it really wasnt that good.
I then looked at the Asrock pro 3 and reviews looked good but then I saw it only had 4x pci slot and as I will be crossfirering hat is a no.
So what would you recommend?
