WC Annihilus
Well, been trying out OCing my 3500+. So far I've gotten it up 2.45 on stock cooling (plus a like 400 mm fan (desk fan), blasted loud but drops temp by 2-5 degrees
) and the crappy PSU that came with the case (I WILL replace that sometime, maybe this weekend) and the method described in Frag's (if you don't like Frag want me to call you FragTek, just say so) guide. I started it out at autoed 1.5 vcore which now seems like a bad idea considering I was able to bring it down to 1.408-1.424
. Goes up to 41-42 C when doing the Prime95 torture test and idles at 34 C. I'll probably be able to pop it up higher (and I still need to do memory torturing) but I just don't have the time atm considering I'm a student (meaning parental limitations).
I suppose you would suggest a new heatsink and fan? Which ones (note I am a student in high school and have no income whatsoever so give me something that has decent bang for the buck)?
Also, for the PSU I'm thinking about going with an Antec SmartPower 2.0 500 W (like $75 or something). Is this a good choice? Would you suggest something else (again, with the same restriction stuff as above)?
Finally, Frag's guide says to lock the agp/pci. How the heck do I do this?!?!?! I can't find anything in the BIOS that mentions this (ASUS A8N-SLI Deluxe mobo if you're to lazy to look at my sig).
O, and mention whatever else you think would be useful to me
PS I'm taking the PRE-ACT tomorrow (blasted parents for making me
) and the PSAT on Saturday so wish me luck
