Peltiers then: make use of the Peltier effect. Also called thermo-electric coolers. A current is passed between 2 dissimilar metals, and one side gets very cold, and the other side gets very hot. The hot side needs to be well cooled, else the heat will kill the peltier. If the hot side is not cooled well enough, the cold side will not become as cold as it could be. A lot of people use them between CPU/GPU waterblocks and the core. The surrounding area (for a mid-high powered pelt) will need to be insulated- cold often means sub-zero.
Because of the nature of the peltier effect, a separate PSU is often needed to power the pelt and component life can be very random- if a pelt fails while you arent at the computer, bad things can happen.
Update: Power requirements. I`ll not bothered with sub-110W pelts because we are extreme (!). Assuming 12V peltiers, and no losses, the current requirements are:
110W: 9.16A
180W: 15A
226W: 18.83A
320W: 26.66A
All these currents are maximum. Peltiers will work on a lower voltage with a lower current requirement.
Yup...thats one hell of a power requirement at the top end! IMHO, its best to get a separate PSU to deal with a pelt- the Meanwell series has the plugs to connect more than one (depending on Wattage) but is expensive. Modular PSUs are a more versatile and, maybe more importantly, cheaper way to power a pelt. The extra cables can be removed, thus keeping the case looking reasonably tidy. I wont list good and bad PSUs for the job, but search by 12V rail. Split rail PSUs will only work with the lower powered TECs- and if going for a split-rail PSU, check how the power is split.
Once the 2nd PSU has been chosen, it needs to wired up to start at the same time as the primary PSU.
See here:
OR
Kenny
I`ll update this in the next day or two to include more info.
Thanks Mav for stickying this!
110W: 9.16A
180W: 15A
226W: 18.83A
320W: 26.66A
See here:
OR
Kenny
