Be Quiet! Dark Rock Advanced with 2500k @ 4.8Ghz
Scarey
I'm about to build a rig with an Asus Sabretooth P67A and 2500k. Now if the chip will clock to 4.8Ghz, as it has a high chance of doing on that board, will the Be Quiet! Dark Rock Advanced handle the heat. I know it's all volts and I haven't won the silicon lottery yet, but does anyone out there run such a setup. Can't get myself to buy the fugly Noctua for this rig
I know there is the larger Dark Rock Pro, but I'd like to see my ram
...or a Noctua ND-H14 with Be Quiet Silent Wings USC fans installed instead...
I run 4.7 on 1.36 Volts and if I turn my fans on minimum it will hit 79 degrees after 18 hours of folding but I might just have a hot chip (water-cooling btw) but I wouldn't say you have a high chance of 4.8Ghz you can deffo get 4.5 Ghz but after that you don't know until you try it
Anyways I wouldn't get the dark rock pro just get a noctua or a silver arrow
