bloodycrashboy
Joined OC3D today and want to share this my first leap into custom loop water cooling.
I decided to go down this path because:
A: water cooled loops look awesome.
B: my graphics card fan noise was really getting to me.
C: I wanted to overclock my GPU's, but running at 77° C (and fan @ 100%) when gaming.
The rig I am water cooling I built back in October 2012 and although it is old, it still performs flawlessly.
Here is the list of parts from the old build.
Corsair Graphite 600T White Case, ASUS Rampage IV Formula Motherboard, Intel Core i7 3930K, G.Skill Ripjaws 16GB (4x4GB) DDR3, Gigabyte GeForce GTX 690 4GB, CoolerMaster Silent Pro Hybrid 1300W, OCZ Vertex 4 256GB SSD. Nexus Real Silent 120mm Case Fans
First off was to buy a water block for my somewhat ageing GTX 690.
Because of its age there was not much choice, but I sourced this from Aqua Tuning in Germany.
The beautifully made Watercool HEATKILLER® GPU-X³ GTX 690 LT
A huge chunk of CNC'ed copper.
my GTX 690 all primed up and ready to go
I also purchased Alpha cool products from the same company
Alphacool Eisbecher DDC 250mm Plexi Reservoir and Alphacool NexXxoS UT60 Full Copper X-Flow 240mm
The pump, an Alphacool Laing DDC310 - Single Edition - silver and Alphacool fittings
The case had to be modified to fit the front radiator, and I also wanted to powder coat it white.
stripped of all plastic
deciding where front radiator is going
cutouts and brace to be riveted
Cut out all but one of the 5.25 drive bays and test fit radiator
back from the powder coaters
