Firstly a big thanks to Phil for my new Baker Extreme and another big thanks to Thickbrit for modding my my new P4c800E and x800xtpe, very professional and switchable too
Now with all this great stuff I need some help on how to install the baker head onto the mobo, a picture might help ...
How do you think this should be fitted, for example ...
Back of mobo install:
Looking at it I could re-use the back of a CPU kit with heater element, then push the long screws through the backplate, then through the back of the mobo and seal the bolt heads and backplate with seal string as normal. This would be like using the back of a standard cpu kit but just with long bolts.
Top of mobo install:
Secure the long bolts with a plastic washer and a nut for each bolt. The mobo can then be installed into the PC with the cpu with a little arctic cermique. Fit the neoprene surround to the baker head and slide onto the bolts that are sticking thru the mobo that we just installed. Secure the head with another nut for each bolt and maybe seal the nuts with seal string?
The picture above makes it look like you bolt thru the baker head and then put the nut on the back of the mobo but then what happens without a heater pad
Any links to any pictures or any install guides on the net would be much appreciated. Cheers
