Bad Axe 2 & Scythe Infinity CPU Cooler
Showoff
Is there any way to check or does anybody know if this cooler will fit on this mobo? I just want to be sure that the mounting holes are correctly spaced and that the cooler doesn't interfere with the blue flaming heat sinks?
Also is this still one of the best CPU coolers out there or is there something better?
Thanks.
I've ordered it now so fingers crossed it fits!
It's only a temporary cooling solution while I look into liquid cooling in more depth. :cool:
Thanks for the comments
Looks like it will fit OK, though I've not installed it yet as I decided to order a E6700 CPU instead of using my existion P4. :cool:
Looks like the E6700 has been delivered today as well and I only ordered it yesterday about 2pm from Specialtech. This is the 3rd item I've ordered from them and the service has been fantastic.
Thats what we like to hear
I reckon it'll fit perfect
