AX1200 inside CM storm trooper?
Bladehawk
the title says it all.
just wondering if the additional size of the ax1200 will make it harder/impossible to fit inside?
Thanks
Visit corsair and see how long the psu is. Then you go CM and read up on the case?
I assume it will fit without any problems.
the case only specifies PSU's with Standard ATX PS2 / EPS 12V no idea what dimensions that is.
and the AX1200 is 5.9" x 3.4" x 7.3"
im just asking for someone who used it if there's room or a ajustable PSU bracket for fitting different size PSU
You could probably have a psu that has double the lenght of a AX1200. Just look at a photo of the case
