Program Packs and Patched Drivers are created by Youp-Pax.org and we are posting this guide for information purposes only to help end users and take no responsibility what so ever. If these programs and guide break any kind of copyright protection please reports this to an admin which will remove this post and any files hosted on our systems.
Source from : http://www.youp-pax.org:8005/forumdisplay.php?fid=13
This guide will convert your Creative Audigy series into Audigy 4 version only in softmod , which means whatever your sound card can do this guide or installation will enable it or make use out of it. The software and drivers in these packages makes sound louder and much better then original drivers. If you have experienced problems with original creative drivers as well as other creative programs this makes installing your card hassle free.
Supported sound card:
SB Audigy (not include SB Audigy LS)
SB Audigy2 (include SB Audigy2 value)
SB Audigy2 ZS series (not include Gateway OEM)
SB Audigy2 ZS Notebook
SB X-Fi series
Few other cards might work , please keep in mind if your card is not retail version it might not work properly so you might have to install your original drivers if this guide doesnt work for you.
Programs you ll need :
Youp-Pax Fi v2.32 Driver and Software Pack - Free / Check end of Post
Youp-Pax Fi v2.33 Driver pack - Free / Check end of Post
Driver Cleaner Pro - Free Click Here Homepage : Click Here
Whats the difference between these drivers and creative drivers?
Well these drivers and programs are hassle free. You might had a successful installation with your audigy card but overall Audigy cards or infact most Creative cards are painfull and time consuming when installing drivers and their companion softwares.
You get all kinds of errors from not finding your audio card to newly installed audio programs ( Creative EAX console etc ) giving runtime errors etc.
If you also have early Audigy cards you might not have all the features enabled in normal installation. With recent updates to MediaSource etc early cards loose functionality due too many errors so i guess Creative just disables them to have less faulty cards or less customer complaints , who knows.
With these drivers you get better sound quality.
Note 1 : At anytime when you come across windows new hardware found wizard please cancel it as we will not install drivers that way. So i ll be skipping those in the following steps. If you dont get the new hardware found wizard then you havent cleaned up your system properly please redo cleaning steps.
Steps to follow.
1 - ) Uninstall all your creative programs related to your sound card
2 - ) Delete Creative folder in Program Files
C:\Program Files\Creative
3 - ) Clean your temporary folders;
C:\Documents Settings\Username\Local Settings\Temp
C:\Windows\Temp
4 - ) Goto Control Panel > System > Device Manager > Sound video game controllers > Right click on your Audigy sound card and choose uninstall , you might need to restart your pc after this.
5 - ) Install and Run Driver Cleaner Pro
5a - From Cleaning Selection Select only "Creative Audio"
5b - Click on Start and wait till it finishes the cleaning.
5c - Close the program and restart your pc.
Now our system is clean of any creative drivers and files we can go ahead with the installation.
6 - ) Unpack "Youp-Pax Fi v2.32 Driver Software Pack" if you havent done so and double click on "YouP-PAX-Fiv2.32.2006.SP2.exe"
6a - At first screen select english installation , click next to continue
6b - Choose uninstall softwares and drivers in the system and clean registry. This will make sure nothing is left over. Click next to continue.
6c - If you agree to authors terms then continue until "Select program features"
6d - In this section it is totally upto you which programs to go for , i have installed all of them and all of them works fine alltogether, there is no conflicts or errors. There are few items starts up when windows starts but thats easy to fix just need to disable the item at windows startup.
6e - Following screens will install whichever features you selected on step 6d. From now on just click on next or continue. When all features are installed you will be asked to reboot your computer. Next step will be driver installation.
7 - If you have also downloaded "Youp-Pax Fi v2.33 Driver pack" you can skip "Youp-Pax Fi v2.32 Driver " installation and just install v2.33 or you can go ahead with the v2.32 installation to make sure everything works fine.
7a - Installing v2.32 , just continue as author pretty much explained most stuff. Once finished installing drivers restart your system and enjoy your new audio card.
7b - Installing v2.33, if you are happy with the results of v2.32 stay with it. As few early cards might give you problems with v2.33 but then again uninstalling the drivers and reinstalling other version takes only few minutes. v2.33 includes bug fixes and has new patched drivers so overall quality and performance is better. Unpack "Youp-Pax Fi v2.33 Driver pack" and double click on "YouP-PAX-Fiv2.33drv.exe" choose English language and continue , you will have 2 options 1 to install v2.33 and other to uninstall , choosing uninstall option will actually also uninstall v2.32 drivers you installed in previous steps so choose uninstall to uninstall v2.32 , you will need to restart your pc and re-run this step to install v2.33.
If you havent installed v2.32 drivers choose install v2.33 , continue and when finished restart your system and enjoy the sound.
Note 2 : While installing drivers you will be asked if you want to have X-Fi demo startup with windows. What it does is, it opens up a folder with X-Fi video demo file which demonstrates X-Fi sound cards.
Note 3 : If you run into PLXcore.plx error when running the demo application in X-Fi folder please check C:\Program Files\Creative\SharedFiles\ folder for above named file. If its not there dont worry as its a mystery error and doesnt actually effect your audio experience nor your system.
Note 4 : While installing drivers you can select which mode to install the drivers. I have tried all 3 versions and Game/DVD mode gives the best performance, specially in games its unbelievable you can hear everyone (CS - CSS ).
Just for info , it looks like a lot of steps to follow but it only takes about 5 / 10 minutes or maybe less but after all i am sure you will be pleased with the results.
You can use download accelarators on these links. I ll try to make a mirror later on not to use authors links and bandwidth. Please also check the authors site if you want to thank him as its totally his efforts.
Youp-Pax Fi v2.32 Driver and Software Pack 380mb:
http://file2.mydrivers.com/sound/creative_youppax232sp2.zip
http://file.mydrivers.com/sound/creative_youppax232sp2.zip
http://file5.mydrivers.com/files/sound/creative_youppax232sp2.zip
http://file6.mydrivers.com/files/sound/creative_youppax232sp2.zip
http://file3.mydrivers.com/files/sound/creative_youppax232sp2.zip
ftp://file4.mydrivers.com/files/sound/creative_youppax232sp2.zip
http://edu.mydrivers.com/sound/creative_youppax232sp2.zip
http://sc.mydrivers.com/sound/creative_youppax232sp2.zip
http://szgwbn.mydrivers.com/sound/creative_youppax232sp2.zip
Youp-Pax Fi v2.33 Driver pack 53mb
http://file2.mydrivers.com/sound/creative_youpax233.zip
http://file.mydrivers.com/sound/creative_youpax233.zip
http://file5.mydrivers.com/files/sound/creative_youpax233.zip
http://file6.mydrivers.com/files/sound/creative_youpax233.zip
http://file3.mydrivers.com/files/sound/creative_youpax233.zip
ftp://file4.mydrivers.com/files/sound/creative_youpax233.zip
http://edu.mydrivers.com/sound/creative_youpax233.zip
http://sc.mydrivers.com/sound/creative_youpax233.zip
http://szgwbn.mydrivers.com/sound/creative_youpax233.zip
SB X-Fi series
Steps to follow.
C:\Windows\Temp
