Hey OC3D Community,
I am building a new rig that is being put into a smaller form factor case. It is a mini tower that can handle an atx motherboard (Lian Li PC-A05N). I love the case but have yet to choose a mobo for it. I am looking at picking up eVGA's new p67 ftw mobo when it comes out in the next month or so. My only problem is this is an EATX mobo. I have never worked with an EATX mobo before, but from what I understand the only difference between it an a regular ATX is the E
correct me if I am wrong ATX = 12" length x 9.6" width. EATX is 12" length and 10.375" width. The difference between these two being .775" in width with no change in length.
Again I apologize this is my first time working with EATX so bare with me please if this is all common knowledge
The mobo trey in the Lian Li PC-A05N is 14" in length and 10" in width. I am thinking that if I installed an EATX boardI would need to drill new holes for that stand offs, this is not an issue I have modded cases before. The challenge is the over hang of .375". First off would it create major issues to have an over hang? I have room inside of the case to do so but is it a problem, and will I have enough mounting points for it to be secure?
If the answer to these questions is an obvious no then I apologize again for bringing up easy facts and questions. If the case is that it is an issue I could probably drill out the rivets and then get a piece of aluminum and create a new tray. This would not be difficult, just time consuming. I could then put in the new tray and every thing would be hunkydory if I am correct right??
If you guys have any thoughts ideas, etc please let me know
Thanks.
Thanks.
