ATI Radeon Xpress 1100
DannyM
I am having lag problems whilst playing Battlefield 2142, and I believe the problem could be related to my graphics card.
The lag seems to be happening in a particular recurring pattern in which the games runs fine for around 2-3 minutes, and then suddenly starts to lag unplayable for around 30 seconds. Then it continues to run fine, and then the lag comes back exactly 2-3 minutes later. I've tried various things to try and sort it out, but I thought maybe it could be something to with my graphics card.
So I was wondering if anyone had any advice on how to sort this really annoying problem out, or anything I should check in my settings to see if my graphics card is running as it should.
Also if theres any other information that you think I should tell you, please just ask.
Any replys would be great. Thanks!
uninstall ur graphics driver, reboot, run driver cleaner pro, reboot, install the latest drivers for ur card from the ati website.
thats what worked for me wen css kept freezing/lagging every few mins.
2142 wont need another gig of ram...its just the xpress series are onboard...for laptops basically so its not going to run smooth either way. More ram would allow more ram useage (intergrated shares ram) so either
New gpu
More ram
or both :p
what cpu u got?
