RizeAllard
Hello mates,
Yesterday I built a new rig for one of my friends and I'm run into a XMP issue.
System Specs:
Mobo: ASUS X99 Deluxe USB 3.1
CPU: Intel Core i7-5960X
Memory: HyperX Predator DDR4-3000MHz 32GB Kit CL15
VGA: ASUS STRIX R9 390X 8GB OC
SSD: HyperX Predator 240GB
SSD: HyperX Savage 480GB
HDD: WD Green ERZX 4TB
PSU: NZXT Hale90 1000W
CASE: NZXT Phantom 530 Black
Cooler: Corsair H110GT Performance
Latest BIOS is in use.
The issue is that when we set XMP Enabled in BIOS it set everything automaticaly (I change it also to manual settings).
It automatically set BCLK to 125MHz and the CPU Core Voltage is increased to 1.200V and ring voltage is also set between 1.1920 and 1.2.
In normal usage its works fine but under heavy load (benchmarks and rendering) it fails, or reboot after BSOD.
I did a fast research yesterda evening and I found that that it may give not enough voltage to the core but gives too much for the memory. (memory voltage 1.395-1.4000). The moduls should be work on 1.350V according to its specifications. So I looked around a bit and I think i will have to increase the Core Voltage.
If you have any experience with this cpu please share your thoughts.
Thanks for your help!
I will post some pictures about the rig. I think its beautyfull.
System Specs:
