Asus Rog Crosshair VI Hero M.2 Bios Settings
KIMTechs
Banned
I have an Asus crosshair VI Hero motherboard. I decided to install an M.2 module.
The thing is what I would like to know and nowhere on Google can I find the right answer.
In the Bios, it has a setting for the M.2. Gen 1, Gen 2, and Gen 3. What is the difference and what should I have it set to?
And can you recommend any other settings in the bios that I should change to get as much speed out of the M.2 module?
I have the Crucial CT500P2SSD8
Sounds like PCI-E generations, stick it to 3 and see if it boots. nVME is implemented over PCI-E.
Especially when manual has them listed like:
