asus ranger v111 bios help
suggs
just commissioned my first build all ok except I cannot access bios via (delete)or after post ctrl>alt>del in post I get a small list ie lock computer ,log off etc, any ideas would be helpfull
Which ASUS Ranger motherboard Z97 or Z170 we need as much details as you can give us, what you have given us it not very helpful
its fine thanks I pressed f2 then after that normal delate seemed to work . but now I am in looks a bit dounting not a clue were to start
If you dont know where to start Im assuming you dont know what you want to do either. Its best to have a read up about what everything does before you go changing loads of stuff.
Once you have learnt it all its pretty simple but as a beginner youll make LOADS of mistakes (we all did)
